SOURCE: Manual for La cross technology radoi controlled digital watch #wt
Downloaded instructions and working on it.
Thank you.
Bernard W. Goering
SOURCE: need instructions for model #2316 La Cross
per the manual at http://www.lacrossetechnology.com/2316/manual.pdf on page 2 section 5 the unit sets its self to the world time radio signal from boulder colorodo on its own after it get the security code from the sensor pack.
SOURCE: How do you change the time zone to central time on the La Crosse Technology 167-1280 clock?
Look on internet, google it. There was not your exact one but you may find one similar enough to do the trick. Companies often reuse code and procedures across products. Or try experimenting. Press or hold menu or mode key and keep on pressing until you get to what you want.
SOURCE: Need manual for la crosse weather station model: WS - 1612 - 11
https://www.manualslib.com/manual/91064/La-Crosse-Technology-Ws-1612.html
SOURCE: My outdoor temp is slowing almost 10 degrees warmer than actual temp outside. What is problem.
You are using a wireless system that transmits signals between the outdoor sensor and the indoor receiver. They are not a perfect match. You cannot make adjustments, thus if your lucky, the factory matched up the devices prior to the sale. You may contact Lacrosse for a replacement outdoor temperature device.
