Televison & Video Logo
J
James Lundsten Posted on Jan 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I use HDMI cable in RX-V1?
Is there a place in the rear panel where I can plug in HDMI cable?
Level 3:
  • Televison & ... Master 6,688 Answers
  • Posted on Jan 03, 2019
Cindy  Wells
Level 3:
Answers
6688
Questions
0
Helped
3532322
Points
21745
The Yamaha RX-V1 receiver does not have any HDMI connections. The spcifications are available from CNET: https://www.cnet.com/products/yamaha-rx-v1/ . You would need some type of HDMI audio extractor or HDMI to component audio/video converter to direct the sound to your RX-V1. The audio output can be either analog (RCA) or digital (optical or coaxial) with teh receiver. This is an example of an HDMI audio extractor: https://www.amazon.com/Extractor-Splitter-Optical-Converter-DotStone/dp/B01KYURMEW . You will need a second HDMI cable to send the video signal to your monitor. The extra audio cables are also not usually included with the extractor or converters.
I hope this helps.
5 Related Answers
Anonymous
  • 1067 Answers
  • Posted on Jan 06, 2008
SOURCE: My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Anonymous
  • Posted on May 31, 2009
SOURCE: Speaker output
Yes, there are relay type switches associated with those outputs. Your RX-V1 is not dying.
Just plug a pin plug in and out of the dead channel to bump the switch. You will hear the speaker
come on. If it doesn't come on,do the plug jack in an out of the pre out again. It will come on.
You can use the test tone to check all channels and rebalance volume levels. You are making the
pre out connect to its power amp. It seems the problem got better when activating those switches. Most likely a cleaning issue. You can also jump the mains and center, and there is also
a modification to jump all channels. I bought my RX-V1 very cheap because of this and love it.
Of course outboard power amp would solve all, but getting this reciever to connect to it's own
power amp has been thrilling as far as bang for the buck. I do use the front effects also, and like
them. It may seem like a pain, but it is worth it to get those channels going.
Anonymous
  • 3 Answers
  • Posted on Jan 04, 2010
SOURCE: I have HDMI cable from TV to RX-V365. HDMI from
the RX-V365 cannot process the audio from the HDMI input. You will also need to connect a seperate audio input (either coaxial or optical) into the relevant input in the rear of the RX-V365
Anonymous
  • 8546 Answers
  • Posted on Jan 28, 2010
SOURCE: Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Marek Podmaka
  • 127 Answers
  • Posted on Mar 02, 2010
SOURCE: yamaha rx-v365 plugged in the hdmi from cable box
You have to configure your DTV input to use optical audio instead of analog dtv audio (red/white plugs). Input assignment should be described in the manual. Come back to me if you have still problems with it.
Yamaha rx-v1600 hdmi output not working
Have you inspected the HDMI socket? I had the same problem and the socket had been damaged by a tight fit cabinet with insuficcient space behind the amplifier. A sideways cable tug on the inserted HDMI cable had snapped a small piece of plastic seperating the two rows of HDMI connectors, and three were splayed out, so no connection when plugged in. Solution was to carefully re-align the connector fingers and glue a tiny piece of insulating material between the two rows. The output now works perfectly. A bit fiddley, but worth the trouble when you look at how much Yamaha would charge to fit a new socket, or even a new board!
Don.
Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
2helpful
2answers
Hdmi cable connection
Your model has a DVI input which is at the top of component 1 section on the rear panel which is for HD input or you can use the RCA plug ins for HD inputs on the component 1 section as well. Either will allo HD to be hooked to your set.
1helpful
Yamaha rx-v365 plugged in the hdmi from cable box
5helpful
I have HDMI cable from TV to RX-V365. HDMI from DVD player to RX-V365. HDMI from DirectTV receiver to RX-V365. Speakers attached. I can watch the TV and the DVD player... but the sound is still coming...
2helpful
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
No sound when using Panny plasma with RX-V3800
Let me see if I understand. You have one HDMI cable linking your TV and AVR? This is only to send video and sound out to your TV from the AVR you will not be able to send sound back over this same cable. You'll have to use the TVs audio out and connect it to an input of the AVR. The "HDMI out" on the AVR is just that Out and not In. For more questions I'd recommend checking out the RX-V3800 RX-V1800 thread over on AVSforum.com
2answers
Dvd installation
Why do you need to connect the rca cables when you get better sound through hdmi?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
