SOURCE: How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
SOURCE: Strict NAT on Zyxel Prestige 660R connected to Negear wireless
I to am having the same problem
SOURCE: Change NAT to open
Go to your router admin panel and into advanced settings and set UPnP (Universal Plug'n'Play) to enable. If that doesn't work then manuallyopen the ports on the IP assigned to your Xbox. Opening NAT all the way is never a good thing. it opens you up for attacks. So with the above mentioned solution, either way, you should game on well!! Go forth and frag!!
SOURCE: Can't join party of friend on HALO 3 while I have an OPEN NAT
The case is the way the network is setup are you connecting him via a router? Make sure your NAT is open on the router as well.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
