SOURCE: Technics SU-G70 clicks but doesn't display or sound
I just got mine back from repair shop, same symtoms, they replaced power supply, in your case it was hit and miss for a while, so maybe bad power supply connections inside.
SOURCE: Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
SOURCE: Hooking up audio components
This was answered here: http://www.fixya.com/support/t1371668-having_hard_time_connecting_various
- OPTiC
http://www.djproaudio.com
http://www.repairny.com
SOURCE: Speakers for Technics SU X933?
check given link for speakers
http://www.fixya.com/myhome.aspx#Answers
SOURCE: TECHNICS SU-V50
Goodevening,I<m looking for an current Drive for mt amplifier technics SU-V50.
