SOURCE: panasonic kx-tg2740 cordless phone - how to change message?
i found this i hope it helps
SOURCE: Panasonic KX-T7730-when receiver on hook plays on hold music
walk up to the phone and without touching anything else, press "1".
No music.
Carl
SOURCE: Panasonic phone rings but line is silent and can't make calls
Tossed out the phone and bought a new much better Uniden. All works great now.
SOURCE: my Panasonic KX-TG2361JXB cordless phone answering
I NEED MASTER PASSWORD OD CORDLES PANASONIC..KX-TG2361JXB
SOURCE: the line 2 ringer is off (it displayes message
Here is a link to your manual.You do not have to sign up for anything and there is no junk after.Click download,then enter the 5 digit code and press download again.It will open a menu.If you want to save it permananetly click save.It will most likely save to your documents folder.For 1 time use click run.You may want to save this site for future reference also.It is excellent and has a wide variety of electronics.There is mention of turning off the ringer on page 23.At the end of the manual on page 59,it mentions for a problem with BOTH ringers not working to refer to pages 23,and/or 38.Page 23 does mention the ringer volume is separate for both I believe,that may be all.Try it out and if that doesn't work try as follows.I don't have a Panasonic,but most phones have the settings available by pressing the menu button,while the phone is off,no dial tone.Pick it up and press menu.Listen in the earpiece and you should hear the menu open.To cycle through the options,obviously it will start at the top so press the directional pad down.When you get to what you want,press right once.To set the ringer,one press right should turn it on,another press right should turn it off again.For other menu options such as setting the answer machine rings before it answers,press right and it should cycle throughall of it's options and repeat after no more are available.When you have all of your options set up,I believe just turning it off will be okay.When you are setting the ringer,it should prompt you to set a certain button to save what you have set.Different manufacturers have different ways,but the basic principles of programs are usually somewhat similar.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.I really encourage responses so I can follow up properly as I know where you stand and asking someone else restarts all the explaining because we cannot see other 'Expert's' responses.Good luck,Greg
Just my kind of luck too.The manual has how to set up everything EXCEPT 1 unit's ringer.The manual says colume,ring tone and everything but.If this does not get your issue solved,please let me know.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
