Question about Polaroid Televison & Video
Polaroid 3211-tlxb power light comes on and turns on with back light with no menu, video or sound
SOURCE:
Garfunkel01
  • 56 Answers
SOURCE: Lost remote
what kind of universal remote are you trying? They're all different
Posted on Sep 12, 2007
  • 71 Answers
SOURCE: Polaroid 15
Do you have to turn it back on with the remote after this?
If so, then you may have set a timer by accident through the menu system.
More information would be required.
Posted on Aug 04, 2009
ekcnoel
  • 998 Answers
SOURCE: No Picture sound only Polaroid 3211-TLXB
Sir the problem of your tv has two possibility, the inverter board may be damage or there is no supply to the inverter board. To check the voltage input on your inverter board you should remove the back cover of your tv, the supply input is 24 volts dc. If you can do this let me know.
Posted on Aug 14, 2011
  • 1650 Answers
SOURCE: polaroid 3211-tlxb have power and sound but no picture. It did smell like smoke. Any recommendations? Unit is 2 years old.
If you can see a picture (dim and low contrast) when you shine a light on the screen from an angle, your backlight inverter may have a burned-out part.
After this test, whichever result you get, unplug the set and use your eyes and nose to search for overheated parts. I have found connectors that overheated because of a poor-quality solder connection on the circuit board. Note that parts, particularly resistors, can overheat because of a fault in another part.
It is common for solder connections to deteriorate if they are frequently run at high temperatures. Sometimes circuit boards "normally" turn brown from heat because of marginal thermal design. Check the solder connections on components in the hot areas.
Static electricity precaution: most digital electronics are easily damaged by static electricity discharge. Avoid touching the metal parts of the circuitry unless you first touch the metal frame of the set to discharge any voltage buildup on your body.
Posted on Nov 10, 2011
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
Jan 19, 2015 | Polaroid 3211TLXB 32 in. LCD Television
Polaroid 3211-TLXB has funny colored picture quality. Turns on and off fine and sound is fine.What could be the source of the problem??
Sounds like T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Polaroid Televison & Video
Polaroid 3211 tlxb 32inch Not powering on (No Red/Blue light illuminating)
Check and replace its main power regulator as card basis. It comes at the center top part of the panel, looking from backside. You must ahve enough knowledge in electronics to do this work. There is no repair to this board, as the components used in the circuit will be very difficult to get from open electronic spare part market. Check this site. You'll get an idea about its working and other details. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Polaroid 3211TLXB 32 in. LCD Television
I have a Polaroid 26"
Sounds like your fiddling may have shorted out the main board of the TV.
Not to say that this wouldn't have happened eventually, there's a good possibility it was defective from the start.
If you have warranty, try to go through that, you should be covered. Otherwise, for a 26 inch, most likely not worth repairing, good luck!
Mar 16, 2011 | Polaroid 2611-TLXB TV
I would like some help with my tv
My Polaroid TV 3211 TLXB (2007) was working fine, turned it off and now won't power up, volts on power supply are normal, red light is on. Control boxes are avaiable. Could this be the most likley problem and are they interchanable with other similsr sets. ? Thanks for any help
Feb 10, 2009 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Polaroid " 3211 TLXB red light no power up?Ive checked for Bad Caps,on the main power supply.I found none,that were swollen or leaking.It looks good.I checked volltage out to volltage inverter.all the out...
hi remove the supply to the main board & inverter, now power your psu if give you this same above voltages , go for new power supply unit. change your power
Oct 12, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Lost remote
Sep 12, 2007 | Polaroid 3211TLXB 32 in. LCD Television
Televison & Video Logo
47 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
