Was able to take end and central brackets out but unable to seperate the 2 parts plastic that hold the glass in place
I seem to be having the same issue with a Maytag refrigerator model M1TXEGMYS01. I would like to thoroughly clean all shelves of this new-to-is refrigerator but I can’t seem to figure out how to remove the glass from the plastic housing. I was able to take the end and central brackets off (that hold the drawers) but I can’t figure the rest of it out... and the manual I looked up didn’t provide any information on separating the housing either. Please see pic attached. Thanks in advance!
First try removing as described by your manual (See below).
The glass may be stuck in the track. Small amounts of liquid may "glue" the glass to track.warm up the compartment by shutting power off and leaving door open. Use a round ended thin spreading knife. Wet it with warm water and try to slide it between the glass and the track. Work it along the crack until they separate with a gentle wiggle.
From the owners manual
Important information to know about glass shelves and covers: Do not clean glass shelves or covers with warm water when they are cold. Shelves and covers may break if exposed to sudden temperature changes or impact, such as bumping. Tempered glass is designed to shatter into many small, pebble-size pieces. This is normal. Glass shelves and covers are heavy. Use both hands when removing them to avoid dropping.
Refrigerator Shelves The shelves in your refrigerator are adjustable to match your individual storage needs. Glass Shelves To remove a shelf: 1. Remove items from the shelf. 2. Slide the shelf straight out to the stop. 3. Depending on your model, lift the back or front of the shelf past the stop. Pull the shelf out the rest of the way. To replace a shelf: 1. Slide the back of the shelf into the track in the wall of the cabinet. 2. Guide the front of the shelf into the shelf track. Be sure to slide the shelf in all the way.
SOURCE: rear glass hatch latch bracket came off glass
not sure of the set up on your jeep off the top of my head, but uruthane glass adhesive is the only thing that is good on glass......its what holds in all the glass on your vehical
SOURCE: driver side car seat side panel will not stay latched
you need new clips ,avable through subaru,i believe they are better than ones equipped originally
SOURCE: White plastic bracket holding headlight
headlight bracket, headlight adjuster, or headlight adjuster bracket
SOURCE: Can the frame under the
How can a 13 year old sub-frame, have rusted out?
You could remove it,media blast it,and cut out rusted sections and weld in new.
You could get a used one from a salvage yard.
SOURCE: 2 of the bolt on
I don't quite understand what sheared off, but all brackets come off the engine. If your bracket is bad, I recommend you get a used one at a wrecking yard. They will have lots of them.
If a bolt is sheared off, did it leave a part behind in the pump? If yes, it will have to be drilled out. Please let me know if you have more questions, and thanks for using FixYa.
