Question about Polaroid Televison & Video
I changed panel type in service menu now my tv comes on and does nothing. Ive tried resetting by unplugging. Any button combos ive tried have done nothing. No manual and no info to be found.
Polaroid 32in 32t2h led smart tv 2018
    Problem Solver:
  • 48 Answers
How long have you unplugged it for most TV's have a battery back up which you will have to wait for it to power down after unplugging could take up to 24 hours they do this to keep settings in case of a power cut
Posted on Jan 03, 2019
SOURCE:
SOURCE: remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Posted on Oct 26, 2007
Slinteriors
  • 8617 Answers
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Posted on May 16, 2008
mediarich
  • 188 Answers
SOURCE: HOW CAN I RESET THE V CHIP TO UNBLOCK ALL THE RATINGS
Try this procudure from the manual.
Notes (for TV RATING and MPAA RATING):
● You cannot access the setup menu when the
“PROTECTED PROGRAM by ...” message
appears. Move to an unblocked channel
before you hit [MENU].
● When you select a rating and set it to
[BLOCK], the higher ratings will be blocked
automatically. The lower ratings will be
available for viewing.
● When you set the lowest rating to [VIEW],
all other ratings will automatically be available
for viewing.
V-CHIP SET UP
MENU
To exit the menu
[CHANGING THE
Posted on Oct 05, 2008
SOURCE: Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Posted on Dec 20, 2008
SD Tech
  • 14553 Answers
SOURCE: i have a ws-65613 and the green light keeps flashing
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it pulls out and secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD Tech
Posted on Sep 30, 2009
I fell asleep watching a movie & my tv usually goes on standby but when I woke up it wasnt on standby & it wont turn on Ive tried switch under the tv Ive try changing fuse & nothing its a Baird 32inch
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 14, 2016 | Televison & Video
How can i fully reset a tv model number GE6601 ... because ive tried the reset in the menu but it didnt work is there another way??
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 12, 2015 | Televison & Video
Tv come on but cant clear the picture from turning red and black how can I get a clear picture?
Without knowing anything about your Tv make or model this is hard; but there should be a reset button in your menues to restore all settings to factory default. Find and use that. However I am suspicious and think the set needs reapir.
Jan 02, 2015 | Televison & Video
Panasonic tv ct-32g7df trouble shooting
Visit this site to get more details about this fault. You might have to enter its service mode window to make it right. The procedure to enter service mode an to adjust the data values to CT Series TVs , are described in detail there. The site name is "Electro-help". search for it. It is an electronic entertainemnt equipments' service help site, in English language.
Jun 20, 2012 | Panasonic Televison & Video
Red line on TV screen.
The LCD panel is defective...sorry I have to give you bad news.
May 13, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
for viewing.
V-CHIP SET UP
MENU
To exit the menu
[CHANGING THE
Oct 04, 2008 | Durabrand DWT2405 24" TV
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
TV Stuck in VCR mode
I used code 191 for my combo unit
Jul 09, 2008 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
Tv problem
le circuit logique n' est pas bon ,
il faut le changer absolument.
Jul 08, 2008 | Toshiba 35A44 35" TV
Televison & Video Logo
29 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
