Wanting to use this model 55r6e hisense roku as my monitor if anyone can help? if no computer plug get USB and change in settings for picture and change to computer
SOURCE: I'm not getting a picture when I turn on the computer.
Ok. This may not have anything to do with your video card at all, as people keep suggesting.
There are two RAM slots on this board. How many sticks of memory are you using, what are the specs on them? And if you are using two, are they dual channel?
This board, I BELIEVE, requires dual channel memory. If you are using two different make in chips, or two different sizes, it may not boot. Also, since it requires dual channel memory, if you're only using one stick, you may have it in the wrong one (some ECS boards are like this). If that's the case, try switching the single stick to the other slot and see if it boots up then.
SOURCE: when used as a comp monitor it's blurry
i would check the resoulution settings in your computer
SOURCE: sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
SOURCE: picture size
You need to go into the menu and take it off of auto aspect. As long as this is on it will adjust whenever it feels like it.
Thanks
Josh
SOURCE: NEED A CODE FOR A HISENSE TV
Hi! You can get the code from the link below-
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/chunghop/rm88e-manual.zip&area=other
