SOURCE: tomtom stuck on waiting for valid GPS signal for 3 days
u need to up date gps if that dose'nt work sounds like it needs to be repaired i had same problem and found its better to buy new on then pay 275.00 to repair due the math
SOURCE: Tomtom not finding gps satellites
i had exactly the same problem, i dont really know how i solved it but first i thought it could be a memory problem slowing the gps signel so i reset the tom tom to factory settings then downloaded the updates from the tom tom home program of corce i lost all my destinations but i didnt want to do a back up just incase one of the updates had a virus or something so if u want to keep them i sugest u write them down first.and then i got a safty pin and pressed the reset button underneath where the memory card goes twice the second time i held it down for about 10 seconds then i looked for updates again from tom tom home. after that in tom tom home there is an option where u can operate your tom tom on your pc so i tryed that and i put in a destination on the pc and clicked on demo tour so i watched the route first it was a bit slow but started to speed up a little. after it had finished i un plugged the sat nav and went for a walk with it around the house soon as i went out side and set a destination it found 6 gps signels,make sure yhe battery is charged to at least half. well i hope anyone who follows my steps gets the same results, thought i lost 200 quid cos i have had it over two years and its only guarenteed for 12 months. well good luck.
SOURCE: my tomtom one says waiting for gps signal and has no satellites
hold on/off switch down for approx 15 seconds & it will reboot
SOURCE: waiting for valid gps signal
Go to TomTom Home on your computer and do a update for your unit. In the update list you should see a GPS quick fix which helps the TomTom's aquire a signal faster. Hope this helps.
The GPS needs at least 3 satellite signals to operate.You are probably in a bad reception area. Move around a bit and try again until you see a signal array of 3 or more!
