Hi Brad
You need to meet up with Phineas T. Ramsbottom the collector at Flatneck Station he is located outside sitting on some barrels have a quick chat with him and this will start the mission Smoking and Other Hobbies.Once you activate this mission you will then be able to mail your full collection of cigarette cards off :)
Hope this helps will attach pictures for the location of mission.
Ps Don’t sell your copies of cards to Fence unless you have more then 1 of that card.
Testimonial: "Thank you Nikki your the best have been stuck on this for a few weeks now lol"
SOURCE: While trying to download game updates to Red Dead
Check you network connection setting on you PS3. That should tell you the ip you are using. To enable DMZ log into your router through your browser usually to do this the address is http://192.168.0.1/. You will be asked a password and user name. Most cases it is "admin" and password is left blank unless someone has changed it. Also with your PS3 connected the router will tell you the assigned ip address under wireless connections.
Hope this helps. if not reply and i will take a in-dept look.
Have a great day.
Correct?? a recommendation or good vote would go a miss ;)
SOURCE: what is undead bait on red dead redemption
I am the Console Guru part
of a six man team that repair PS3's - Xbox 360's and Wii's
I want to just make it clear to you, that you can
repair the following probems at home with a good repair guide. There is no
technical knowlage needed you simply do what you see on the guide do that
click here to download repair guide................
SOURCE: My red dead redemption game
Did you purchase the game brand new or pre-owned? or is it a knock off copy? i only ask about the knock off copy idea because members of the military can aquire such things quite easily.
SOURCE: When playing Red Dead Redemption
If a game freezes, then the problem is usually due to the PS3 overheating. The PS3 needs good airflow through the vents so make sure that you don't put it in a corner or in a place where the hot air won't linger around for long like near a window. Also, don't play for too long; give your PS3 a break every once in a while (1 minute breaks don't count) :)
