Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Hi
time is set on the PBX depending on the version of CM its either done on the web interface or from the command line.
If you are on > CM1 there is an NTP section to add a network time protocol server IP address, the pbx will correct the timeslip with that server
see support.avaya.com for more details
if you have a definity pbx. i go in the gui interface on site administration and i just setup autodial next to lines i want. so when the user goes through the menu on the phone and select prog and when they select a line they can input whatever number they want on that line.
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
