Question about GE Washing Machines
I have a front loading Ge wbvh5200j1ww it is leaking water down the front panel under the door. Is this the door seal or rubber about tub?
    Top Expert:
  • GE Master
  • 6,289 Answers
Most likely yes.
Posted on Jan 19, 2019
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Replace the seal or rubber of tub
Posted on Jan 02, 2019
SOURCE:
Wbvh5300k2ww washer leaking
door gasket or door boot or the door bellows, it can be referred to by any of these 3 names
Nov 11, 2012 | Washing Machines
I have a GE WCVH 6260 front loading washing machine. It has a massive tear (approx. the bottom third) in the rubber door seal. All the water drained inside the unit, beneath the tub, on down to the floor...
Please join us in this petition to have GE recall this front loading washer! Thanks :)
http://www.thepetitionsite.com/739/633/604/recall-ge-wcvh-front-loading-washing-machines-due-to-smoking-fire-hazard/
Dec 01, 2010 | GE WCVH6260F Front Load Washer
Water leaking out of door , seems like it might be a problem with the door hinge ?
Not likely that you have a hinge problem, but it can happen, especially if water has been dribbling down the back side of the front panel from the dispenser area, getting on the hinge, and causing it to bind up. Replacing the hinge is a pain because the screws are put in with thread lock, requiring heating or even drilling in some cases. If you have water dripping down the front of the machine from the door, the most common reason is that there is some lint or hair on the bottom side of the glass door, preventing a complete seal to the gray rubber gasket. Generally, just cleaning off the bottom of the glass door will fix it. If that does not do it, you can try moving the spring clamp (which holds the front of the gray tub seal) from the bottom (6 O'clock position) to the hinge area (9 O'clock position) Sometimes, the leak is caused because someone pushed the washer into place by placing their hands just below the door and actually deformed the metal front panel inward, preventing a seal between the door glass and the gray tub seal. If that is the case, it may be corrected by removing the spring retaining clamp, taking the front of the gray tub seal off, pulling outward a bit on the metal panel at the bottom of the door openings, and replacing the seal and retaining band again.
May 09, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Rubber Seal leaks
You have to replace the whole door seal.It can be done through the port hole,difficult but achievable or you can strip the front of the appliance off and do the inner part easier.
Unplug the appliance.
Open the door and take the seal retaining ring out of the door seal.
Peel the door seal off the front panel and fold it inside.
Take the seal retaining ring/spring out of the tub side of the seal.
Pull the seal off and take it out of the appliance.
Fit the new seal to the tub,look at the seal and tub for matching arrow marks to help align it.
Fit the retaining ring/spring into the groove in the seal and over the lip of the tub.
Fit the seal to the front panel and then fit the retaining ring into the seal.
Restore the power to the appliance and leak test it.
If you find you can't get the seal on.
Take the top off the appliance.
Take the dispenser out.
Take out the screws revealed.
Take out the screws holding the door lock.
Take off the plastic cover below the door and remove the screws revealed.
Take the front panel off.
If the panel won't come down and off there will be a hidden screw that requires the facia panel to be removed.It's snap together plastic,just release the catches and carefully remove the facia.
Take the screw out, take the panel off.
Fit the inner part of the seal to the tub.
Reassemble the front of the appliance.
Fit the seal to the front.
Leak test the appliance.
Apr 06, 2010 | EuroTech EWF150 Front Load Washer
Leaking water out bottom of front load washer
You will need to remove the lower toe panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the washer up with something (a 2x4 works well for this) will give you better access to the screws.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If the bellow is intact, check the rear bellow seal where it connects to the front of the wash tub. If the clamp comes loose the bellow can shift and begin to leak. Tighten if necessary.
Check the drain pump and hoses to ensure they are not leaking. The drain pump is directly in the front under the wash tub.
Check the area directly below the wash tub. If the leak is coming from the wash tub iteself, you may have a bad tub seal. A replacement gasket doesn't cost much at all, but the labor involved is extensive.
Check the air dome on the lower right hand side of the wash tub. There should be a small air hose attached that runs all the way to the pressure switch. This small air hose is how the pressure switch senses the pressure differential in the wash tub and determines when to shut the water off. If the air hose comes loose, water will pour out of the air dome into the cabinet bottom. Reattach if necessary.
Another simple problem is the dispenser tube(s) that come through the door bellow. Sometimes, these small tubes will work their way behind the rubber in the door and leak when the washer attempts to fill or rinse. This is a simple matter of adjusting the tubes to ensure they are seated through the door gasket properly.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
NOTE: You can refer to searspartsdirect.com for some excellent exploded view diagrams of your washer for reference in locating components. If y
Oct 23, 2009 | Kenmore HE2 Plus Front Load Washer
We have a Kenmore Elite Smartwash Quietpak9, It gave no problems for about 3 years. However, it has begun to leak. It doesn't leak every washer load, but mostly if there are towels in the load. We had...
You will need to remove the lower kick panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link epxlains how:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
NOTE: The repairman was correct about leaving the door open to prevent mold and mildew. Due to the water tight seal of these doors it is important to leave the door open when not in use to prevent any residual water from becoming stagnant and allows the wash tub to air out. Also, you should always check and clean the area around the door. Small articles of clothing can get stuck in this area and begin to mildew as well. I have repaired this washer numerous times and personally own one. I have never had a problem with it in the 9 years I've had it, following this regiment.
Aug 29, 2009 | Kenmore Elite 45986 Front Load Washer
Water is leaking underneath and pouring out of side
If this is a Whirpool Duet front loader, you will need to remove the lower kick panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
535 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
