Newly installed Edge browser does not open webpages, get message Cannot connect securely to this page, may be outdated TLS security settings on the webpage you are trying to open.
SOURCE: Reg : Navigation to the WEBPAGE is cancelled
right click to internet explorer and select properties and goto advanced tab and then select restore defaults and then close the internet explorer and then open the IE
SOURCE: I have trouble browsing the internet. I often get
Check the privacy settings and see if they are too strict this will cause some sites to not download. In Internet Explorer click tools>Intenet options>privacy. It should be set to medium so no cookies are blocked. If this is ok then yes you are having hardware connectivity problems. You're losing the connection before it can reach the site.
SOURCE: DLink router connected to internet but webpage doesnt open
With an Ethernet cable, connect your computer _directly_ to the cable-modem (or DSL-modem), bypassing the D-LINK router.
Now, can you web-surf?
SOURCE: The Webpage contains content that will not be
Go to Internet Options->Security Tab->Custom Level...button.
Look for "Display Mixed Content" option and choose the "Enable" radio button.
Click OK.
See screenshots of the solution here: http://www.wallpaperama.com/forums/windows-disable-this-page-contains-both-secure-and-nonsecure-items-t274.html
Microsoft's Internet Explorer 8 (IE8) browser includes "add-on" applications that can be downloaded and installed from Microsoft, or third-party providers, into Internet Explorer.
Occasionally, add-ons may conflict with other add-ons or software on the computer, causing errors.
These can also occur when IE settings conflict with newly installed add-ons.
Resolve add-on related error conditions quickly in IE8 by resetting Internet Explorer to Microsoft defaults.
Click the "Start" button. Click "Run" or "Search," and type "inetcpl.cpl in the "Run" or "Search" box, and press the "Enter" key.
Select the "Advanced" tab in the "Internet Options" window, then click the "Reset" button.
Click the "Reset" button again to confirm that you wish to reset Internet Explorer to Microsoft defaults.
Select the "Close" button, once the display indicates that the reset process has been completed.
Click the red "X" in the upper-right corner of Internet Explorer to close the browser.
Open Internet Explorer and the errors should be resolved.
also
Experience problems with Internet Explorer 7 right off the bat, and it may be due to installation problems.
Make sure you reboot twice after installing the new browser.
Download any updates for IE7.
Check the Microsoft website for recommended updates if you don't have automatic updates turned on for your computer.
Check your add-ons, those "extras" like ActiveX controls for your browser, if you still experience problems.
After accessing "manage add-ons" through the "Tools" menu in your browser window, disable all add-ons, and try browsing.
If you can successfully browse without errors on the page, then one of your add-ons may be the culprit. Enable add-ons one at a time and try browsing.
Once you find the problem, delete it or update the add-on to work with Internet Explorer 7.
Contact Microsoft if a website denies permission for entering when it shouldn't.
It could be a problem with document. domain property or the protocols of the URLs not matching.
Update and run the most recent version of JavaScript. JavaScript is a scripting language used on many websites.
Adjust security settings in the browser if you still experience page error messages.
Select the "Tools" menu and access "Internet Options." Under the "Security" tab, choose "Custom Level" to pull up the security settings window and review for possible problems.
Hope this helps
