SOURCE: Plastic inside door is shredding apart
Hello kwheersink
Welcome,
Make sure you are not using to much detergent.
You should be using HE, or High Efficiency Detergent.
And only the amount that the manual for the washer tells you.
To much and it will slowly destroy your Seal and bearing. Plus any rubber or plastic parts it comes into contact with.
Definitely replace this now!!
How old is the washer?
Let me know how you do and the answers about your detergent habits.
Waiting your response.
Thank You Huuum
Please remember to leave a rating!
SOURCE: rug and floor nozzle brush not moving
What I had to do was take apart the vacuum head...which is very confusing, and the manual doesn't tell you how...the "secret" is to use a flat screwdriver to pop out the little wheels...there are two other screws "hidden" beneath them. Be careful as this exposes all the electrical parts as well - make sure you're unplugged! : )
SOURCE: Rubber seal around the door of my washing machine
has a seal clamp come off or has it been damaged. is should not be loose on the front of the case.
SOURCE: When trigger is engaged under pressure nothing happens.
Make sure all of the water is bleed out of it buy holding trigger down with motor not running until theres is not more bubbles or air that comes out..Make sure where the inlet for waters screen is not plugged..You may have to back flush washer to clean out or to unstick the pressure valve..Hope this helps you and have a great day
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
There is a small helix gear attached to the shaft of the main drive motor. It cracks or shreads on the inside. You will have to replace the main motor. Not real expensive or difficult to replace.
Please try the following suggestions to see if you can get your machine suctioning properly:
1) Remove the Tank-in-Tank Assembly and place your hand over the motor intake valve. This valve is located next to the Floor Nozzle gasket (at the top of the Floor Nozzle window) and behind the SmartMix Bottle. If you feel vacuum-like suction at this area, your suction power of the unit is working but air is escaping at some point. If there is no suction at the motor intake valve your machine will need to be inspected by an Authorized Service Center Technician.
2) It is possible the Floor Nozzle on your machine is inserted incorrectly. This would directly affect the suction of your machine. Please follow the directions below for removing and replacing the nozzle.
Before starting, please be sure the machine is unplugged and the machine handle is reclined.
To remove the Floor Nozzle window, first detach the Phillips head screws located at the base of the nozzle. Then, remove the Tank-in-Tank Assembly. Next, pull forward at the top of the Floor Nozzle window to release the tabs of this window from the receiving holes of the machine. This window is designed to allow access for cleaning.
When replacing the Floor Nozzle window, please be sure the tabs at the TOP of the nozzle are properly inserted into the receiving holes provided. If you do not have the tabs in place properly, the suction power of the machine could be affected.
Rotate the window down into place and replace the screws.
3) Ensure that the Ready Tools knob (diverter knob) is in the proper setting and the valve opens and closes freely. Ensure the black foam gasket is in place under the valve.
4) Check to ensure the Tank-in-Tank assembly is seated properly and that it is not full of dirty water. (If this tank has a drain cap, make sure it is in place and that it has a black o-ring).
5) Check the float and baffle to ensure they are properly installed on the Tank-in-Tank. The larger square portion of this part should be below the clear baffle of the tank with the red flag portion of the float resting on top of the baffle.
6) Check the Tank-in-Tank and lid for damage. Is the lint screen clogged? Make sure the lint screen is in place on the tank lid and not placed into the motor duct. Also, clear the holes on the lint screen.
7) Check to see if the upholstery hose has suction. If the hose has suction and the floor nozzle does not, check the diverter valve to see if it opens and closes freely. This can be seen through the Floor Nozzle window as you switch the diverter knob from the floor to tools setting.
I have found this so i think this answers my question.
Question
How do I remove the clear floor nozzle window on my machine?
Answer
Before starting, please be sure the machine is not plugged in and the machine handle is reclined.
To remove the clear floor nozzle, first detach the phillips head screws located at the base of the clear floor nozzle. Then, remove the tank in tank assembly. Next, remove the rectangular gasket at the top of the nozzle, and pull the clear floor nozzle forward to remove the tabs from the notches. This clear floor nozzle is removable so you may be able to access this area and clean.
When putting the clear floor nozzle back in place, please be sure the tabs at the TOP of the nozzle are properly inserted into the notches provided. If you do not have the tabs in place properly, you may have a problem with the machine's suction.
Rotate the window down into place, replace the screws, and replace the rectangular gasket.
If you would like additional assistance, please contact BISSELL Consumer Services at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET or email us by clicking on the Email BISSELL tab at the top of this page.
Reminder: When you have completed the deep cleaning process, it is recommended to return the SmartMix dial to "Water Only" prior to storing the machine.
How well did this
