Jef Forrer Posted on Jan 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can IO down load a Manual for Bose AV48 Media Centre?
Level 3:
  • Bose Master 6,688 Answers
  • Posted on Jan 02, 2019
Cindy  Wells
Bose Master
Level 3:
Answers
6688
Questions
0
Helped
3532759
Points
21745
Do you mean the Bose Lifestyle AV48, the main unit in the Lifestyle 48 DVD home entertainment centre? If so, the Installation and Operating manuals are available on the product page: https://www.bose.com/en_us/support/products/5_speaker_home_theater_support/ls48_series1.html#v=ls48_series1_black . The direct link to the operating manual is currently https://assets.bose.com/content/dam/Bose_DAM/Web/consumer_electronics/global/products/speakers/ls38_series1/pdf/opg_en_ls48_series1_ls38_series1.pdf .
I hope this helps.
4 Related Answers
Anonymous
  • Posted on Apr 15, 2008
SOURCE: frozen bose lifestyle 48 IV
turn off the accoustimas, unplug the power code from the accoustimas and the media center and leave it for 15 sec. Then, plug the power code onto the accoustimas and turn it on. then plug the power code of the media center on. Turn media center on.
hope this helps
Anonymous
  • Posted on May 04, 2009
SOURCE: Volume control
I had the same problem as this, but have lost my remote, so the system is know useles. Any way back to the point if you wiggle the cable around that goes in the speaker zone port then turn it off and back on then it should work :-D.
Anonymous
  • 5 Answers
  • Posted on Nov 11, 2009
SOURCE: Connection to Bose V30 System
check hdmi setting from ur tv and ur dvd connection
woodzowl307
  • 679 Answers
  • Posted on Apr 06, 2010
SOURCE: can i use a non-bose amp to drive the speaker
Yes you would be able to use a non bose amp. All the speakers should have crossovers in them, If you do start at a low volume first, you can blow your speakers if your amp is too big and volume is too high.
Can i use a non-bose amp to drive the speaker system from my Bose AV48 system. The original Bose amp and dvd player is too glitchy
I am attempting to connect a computer monitor to my bose lifestyle 38 system. The monitor has an HMDI input
I think that will be hard to do as I own an AV38 and there is no HDMI feature on my BOSE SYSTEM. I had to use the AV inlet. The AV48 DOES have the HDMI feature.( Unless you have a much later model AV38 that has the HDMI feature.
4helpful
I have a BOSE Lifestyle 48 without sound
Not sure if this is the same problem, but I lost audio from the Stored, TV, Radio and my external speakers, but still had audio for the CD/DVD. I contacted Bose (Australia) support and they talked me through a solution that worked for me.
Remove the power cord from the Media centre, then while holding down the 'All Off' and 'Vol down' buttons on the Media Centre, reconnect the power (and continue to hold the buttons down). After 10 secs, release the buttons and turn the Media centre on. Everything worked fine for me after doing this.
Full marks to Bose for the phone support. I hope this helps someone else.
2answers
TV audio through Bose Lifestyle 38
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
Frozen bose lifestyle 48 IV
hope this helps
2helpful
Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
21helpful
7answers
Life style error codes 801 & 802
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
