Question about Razor E100 Electric Scooter
I have a carbon fibre electric scooter that has stopped working it will not turn on even though it shows green on charger
SOURCE:
  • 40 Answers
SOURCE: ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Posted on May 13, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
  • 5 Answers
SOURCE: When I plug in the charger is shows green, but the
Check the voltage output of the charger. It should be about 28 volts. Most likely your batteries are dead (over 2 years old?)
Posted on Apr 11, 2010
  • 177 Answers
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
Posted on Jun 05, 2010
skychief2001
  • 21873 Answers
SOURCE: my charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
Posted on Jul 29, 2012
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
Batterys showing full charge but when my daughter gets on in power kicks in then stops
razor hasnt been charged for a week as i needed a new charger i had 1 scooter charging over night yet still nothing , i bought a new charger its showing green on the light do i have to wait till it shows red and then wot if it doesnt still work
Dec 17, 2013 | Razor E100 Electric Scooter
My leo mobility scooter charger light shows green as soon as connected to power it remains green when attached to the battery and does not charge
Hi, that could be because it can't see the battery voltage in most cases or at worse the batteries refused to charge, or your charger has called it a day , check the fuse on the scooter as well...
Regards
www.gewizrepairs.co.uk
Oct 06, 2013 | Electric Mobility 4 Wheel Power Electric...
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
Feb 26, 2013 | Free Rider 2 Freerider Luggie Compact...
My charger light shows always green and it does not charge the scooter.
Jul 29, 2012 | Razor E100 Electric Scooter
Scooter dash lights flash up and down .were normaly they come on and stay at top .they just constantly run up and down ..batteries show on charger in boot .that its fully charged
Hi. Some scooters will show a pattern like this while the charger is operating, but when the charger is turned off it should stop. Some internal chargers have a relay that is activated while the charger is on to disable the scooter. Does the scooter operate properly after the charger is turned off? If not, then unplug the charger where it connects to the batteries inside the scooter and see if this helps. If this helps, you might need a new charger.
Good luck. Neil.
May 14, 2010 | Electric Strider Maxi 4 Wheel Mobility...
The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Jul 11, 2009 | Golden Technologies Avenger 4 Wheel...
Schwinn S1000 illuminates both green & red light, but no power
I am having the same problem. By all indications it looks like the motor controller is the problem. Everything else works OK. I am pulling the controller tomorrow and replacing. If that doesn't work I am junking it.
May 12, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Razor E100 Electric Scooter Logo
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
ROB
Are you a Razor Toy Expert? Answer questions, earn points and help others
