SOURCE: Hotpoint WMFUG 942 Stops 15 min after starting cycle, on full F -06 error code
F06 is a water level fault.
It will either be due to a faulty vacuum switch (which is the hockey-puck thing with the little tube to it,
or it will be not draining properly because of a blocked or faulty outlet pump or filter.
The worst case scenario is that it might be a control board failure.
Check the filter & pump first.
Check to see if the vacuum switch switches by sucking or blowing into the tube.
Sometimes just doing that can free it up if was stuck.?
Best of luck.
