Have you checked the voltage in the car? I know this sounds like a dumb thing to check, but if your voltage is dropping than the amps current draw will go up. Also have you ran at least 2 runs of 1/0 1 for ground and 1 for positive?
It sounds like the main power transistors may be bad. Common with big amplifiers. The transistors can be better tested out of the circut. Sometimes only a few are the ones causing the fault. They may not all be bad. It is always recomended to replace a transistor with the same part. If the correct part is not avalible you can usually substitute it with one of similar specifications. Replacements can be better or worse, usually no noticable difference is present. Also there are usually very low ohm resistors that may be damaged usually connected near the transistor. It takes a very sensitive meter to check them so I replace them too while I have it apart and to ensure correct operation. C2559 is the part you have. It does not cross to any radio shack (Archer) numbers... It does cross to other # avalible online at DiGiKey.com.
i have a jl audio amp 1200/1 in my silverado with two shallow 13.5 subwoofers and my amp keeps shuting off and blowing breakers after playing for a minut or less.i tride bridging it and it sounded better but same thing hapend.then i used only one 13.5 sub and its still blowing brakers and then i changed it ti fuses and same problem came back... does any body have any sudjestions.. power wire is 1/2 inch thick and ran two grounds ..one of them to the trucks frame.may i have a difective amp?
