SOURCE: Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on [email protected]
SOURCE: Screen is all Shades of Red....
You need to remove the front tv panel, search for the screws right behind the screen and speaker area on the sides of tv. Should be four of them, carefully remove the lower have/quarter and you will find a control box, 6 knobs. Try adjusting them to clear the problem, each color has its own knob, be sure to mark their original position befor adjusting. When you find the red adjustment knob, you should be able to turn it down enough so that it doesnt overpower the rest of the colors. Good luck.
SOURCE: green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
SOURCE: Green Screen
put a fan behind it, if it works then its heat related if not then you probably need a new main board.
SOURCE: My 32inch Proscan lcd tv wont power up the green
If you can open than open your LCD tv & checked Inverter Borad it have White & red color connector may be this board is defective.
