The wall oven probably has a bad door lock. If the door is stuck shut, average repair cost ~ 300 dollars - 500 Dollars max. Worth calling service if you lack the confidence or experiece to tackle this expensive machine. If the wall oven door actually opens and isn't locked shut, try holding down the door switches to see if you get a response or if the error clears. Recommend calling GE service for this repair if available in your area. 1800 GE CARES
SOURCE: Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
SOURCE: f9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
SOURCE: GE ZET938 Monogram single 30" convection wall
Hi. Error F2 in your oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced.
SOURCE: ge wall oven zet1sm1ss shows error code f9 in
F9 error.This is a problem with door lock circuit such as
pinched wire between Electronic Range Control (ERC) and door lock switch.
But as you mentioned that,you have already replaced the door switch,still this error comes up.So check the internal cooling blower fan connections and wiring.If the cooling blower fan connectors is burned out or shorted then internal unit gets over heated and this causes the problem.Is the internal fan running.
---------------check out.Keep updated.Thanks.Helpmech.
