I need to access the area to check wiring. the unit came with the house when we bought it. have no idea how old it is. freezer lights and dispenser lights work fine. just the refrigerator light is gone.
Unplug and with a small flat head screw driver pull out the center piece in the bulb outlet just a little. Try this first.
Probly corroded..unplug unit n clean socket w vinagar or pad
You’ll have to figure out how that receptacle comes out. Some just snap in. There should be 2, maybe 3 wires going to it.
Electricity is nothing to mess with call a proper repair person before you have an accident
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
