Video Game Consoles & Games Logo
E
Ethan Sumner Posted on Jan 01, 2019
How to remove the family manager settings off of my ps4
Matthew Mayotte
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 16 Answers
  • Posted on Jan 02, 2019
Matthew Mayotte
Contributor
Level 1:
New Friend:
Night Owl:
Answers
16
Questions
0
Helped
5295
Points
23
Go to your settings and go to the family management settings. Type in the pin number and then you can disable family manger
Connecting Kenwood vr-405 to ps4
o connect a Kenwood VR-405 to a PS4, you will need to use the audio and video outputs on the PS4 and the audio and video inputs on the Kenwood VR-405. Here are the general steps to follow:
  1. Connect the HDMI cable from the PS4 HDMI Out port to the HDMI In port on the Kenwood VR-405.
  2. Connect the audio cable from the PS4 Digital Out (optical) port to the Optical In port on the Kenwood VR-405.
  3. Turn on the Kenwood VR-405 and set the input to HDMI or Optical, depending on which cable you used.
  4. Turn on the PS4 and adjust the audio settings on the PS4 to output audio through the HDMI or Optical connection.
  5. Adjust the audio settings on the Kenwood VR-405 to match the audio settings on the PS4.
It is important to consult the user manual of both the Kenwood VR-405 and the PS4 for specific instructions on how to connect them and adjust the settings. If the VR-405 doesn't have a HDMI input, you can use an HDMI to composite adapter to connect the PS4 and the VR-405.
How do i remove the Cinavia code 3 from my PlayStation 4
If you are using PlayStation and then you come across Cinavia Message Code 3, you can go to Settings >> date and time settings, then set the date and year one by one to fix it. But after setting, the Cinavia Message Code 3 will appear minutes later.
Another way to solve the Cinavia Message Code 3 is to use a Cinavia removal to remove the protection. You can try Leawo Blu-ray Cinavia Removal
How do you get a stuck disc out of a ps4
  1. Step 1: Remove The Glossy Section of the Cover. Turn off the PS4. ...
  2. Step 2: Locate the Manual Eject Screw & Remove the Disc. With the glossy panel removed, you will see two sets of vents lining the outer left edge. ...
  3. Step 3: Put Everything Back Together.
Here How to Manually Eject Disc Stuck in Your PS4 PlayStation LifeStyle How to Manually Eject Disc On PS4
2answers
How to fix a ps4 that needs a software update via usb
First, from your computer click the Download Link
to download the latest PS4 Update. Make sure you don't rename the downloaded file.
After download, plug your USB onto you Computer. Open the USB and make a folder inside named PS4 (you need to use Uppercase letters). Inside that folder create another folder named UPDATE. Then, just take the PS4UPDATE.PUP file you downloaded from the provided link and put it inside the UPDATE folder.
After that you just connect your USB with your PS4, and then from the Main Screen of your PS4 go to Settings -> System Software Update and just follow the instructions on-screen.
PS: Make sure you DO NOT turn off the console or remove the USB from the PS4 while the update is taking place, otherwise the system may be come temporarily or permanently damaged.
Download Link
http://dus01.ps4.update.playstation.net/update/ps4/image/2015_0625/sys_4f1c6d8597242ff346612773ffbc10ad/PS4UPDATE.PUP
Why no sound?
no mention of cables used . Could be analogue cables in ps4 on analogue output . Digital output would have a digital output port using digital cabling I would deduct on ps4..
I have a jvc-rx778v and I have a ps4 I can't get any sound from the ps4 to the receiver I put in digital setting and tried each digital input
Use optical cable for the digital sound from ps4. Also, set the receiver to optical sound setting. It should work.
ld
How to Fix error code Ce-34878-0 on PS4
If you are experiencing this ce-34878-0 error code, please close the application and then install the latest system software and game patch. If the error occurs again, initialise the PS4 system after back-up of the save data and please also submit any crash reports after re-booting your console when the error occurs. Sure the "solution" isn't exactly helpful for those that have already lost their save file, but it's good to have something to refer to when the error hits. Until Sony patches the PS4 for this error, this is probably as close to a fix as we'll get.
1helpful
2answers
Two problems, PS4 ejected discs and now wont turn on
To stop your PS4 from ejectin disks, remove the glossy HDD panel, and locate the PS4 eject screw its small at the top of the PS4 (by top I mean the way you would see it if you had the PS4 stood up vertically), and tighten it.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
