SOURCE: Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
SOURCE: where to find a replacement connector for my technics st-ch510 audio system
Try looking at tritronicsinc.com. They are a distributor for Panasonic parts. Use the model number to search their parts listings. If you have difficulty, call them up for assistance.
Dan
SOURCE: remote control for technics hi-fi
I had the same system... still have the remote if you're interested in it?
Regards, Gary.
SOURCE: Technics ST-X302L tuner - Unit not powering on
who is original remote control per technics su-x303
SOURCE: stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
