Question about Nintendo Computers & Internet
My Nintendo switch screen acts like its lighting fireworks while playing
Any time I do anything like press a button that happens
  • Nintendo Master
  • 1,554 Answers
Could be a defect in the main board and needs replacement.
Posted on Jan 02, 2019
SOURCE:
SOURCE: wii eject button broken
open it up. get a Wii triblade tool for $2 and open it. just unscrew the face plate, shift the button so that it will hit the button again, and screw the faceplate back on. Wont void warranty.
Posted on Jul 30, 2008
steve6375
  • 395 Answers
SOURCE: not booting
remove battery and try again (on mains). If it works then battery may be too far gone!
Posted on Aug 03, 2008
  • 15 Answers
SOURCE: Problem with PSP "home" button
Hiya i have that same issue. when i watched my hands intensely i found that i actually do tap the button accidently and dont notice it if im too involved in a game if you make sure your left hand steers clear of the 'home' button im sure you will notice a difference
Posted on Jan 17, 2009
SOURCE: Tv tries to come on then goes off
I HAD THIS SAME PROBLEM AND FOUND OUT THAT THE 2 CAPACITORS ON THE POWER SWITCH WERE LOWER VOLTAGE THAN WHAT MY SET NEEDED--THEY ARE TURNING OFF AND ON BECAUSE THEY ARE ALMOST BLOWN. WHEN THEY GO TOTALLY OUT THEY WILL NO LONGER TURN ON.
WHEN YOU VIEW THEM THEY WILL HAVE A( PUFFED UP HEAD) ON THEM AND LOOK LIKE A BATTERY WITH 2 WIRES ON TOP. ONE IS BIGGER AND TALLER THAN THE OTHER.
IF YOU'RE IN BACK OF THE SET THEY ARE ON THE LEFT SIDE. THE BACK CASE MUST BE REMOVED FIRST- AND THE MIDDLE RACK DOES COME OUT TO LOCATE.
TURN THE SET OFF BEFORE STARTING AND HAVE A LITTLE KNOWLEDGE ABOUT SOLDERING, AND GET THE CORRECT SIZE CAPACITORS--MINE WERE UNDER RATED FOR MY TV, OF WHICH CAUSED THEM TO START TO GO OUT. PROBABLY MOST OF THEM ARE NOT THE PROPER AMPERAGE.
GOOD LUCK!!!
Posted on Apr 04, 2009
SOURCE: phone will not switch on
i have a lg kp500 and it will not turn on i have to take battery out then put it back in
Posted on Jul 14, 2010
Screen touch
Refer to the trouble shooting at Nintendo. Your screen may not be working due to the game your playing if any. If that's not the case you may need to recalibrate your touch screen.
http://www.nintendo.com/consumer/systems/dsi/en_na/trouble_screen.jsp#respond
Aug 15, 2013 | Nintendo Dsi Pink Console
Fifa 09 wont let me past press A screen
Same thing happens to me. It won't let me past Press A screen unless I use player two.
Jun 12, 2010 | Nintendo Fifa 09 for Wii
Every time I try to play a game the screens goes black and it says; an error has occurred. Press and hold the Power Button to turn the system off. Please see the Nintendo DSi Operations Manual for help...
Every time I try to play a game the screens goes black and it says; an error has occurred. Press and hold the Power Button to turn the system off. Please see the Nintendo DSi Operations Manual for help troubleshooting. But I don't have the manual, ca anyone help me please.Thank you!
May 12, 2010 | Nintendo DSi Black Console
The screen will not come out and the unit will not play. The blue light comes on to switch from radio/cd/tv, etc. and the red light comes on when you push cd eject, but otherwise it will not play any
MAKE SURE YOU PRESS THE SOURCE BUTTON AS THE SCREEN WOULD NOT COME OUT FOR THE RADIO BUT WHEN PRESSED AGAIN WILL PROBABLY COME OUT FOR THE TV
May 04, 2009 | Car Audio & Video
Wii has frozen playing guitar hero
Hi. I got the same thing playing GH but without the nunchuck. Use the hand controller to re-sync. Press the sync button on the console FIRST and then the sync button on the hand controller SECOND.
I sat for hours trying to work it out - and it cleared the problem within seconds. Hope it works for you too.
Feb 20, 2009 | Nintendo Wii Console
Nintendo Wii console gets a black screen when switched on
not to be mean but buying a modded anything usually voids the warranty.
Not having anything to go off of regarding the mod means that we don't know if it's a faulty weld on the board or anything like that.
Try doing a system reset (if there is a reset button) and see if that works
Jun 08, 2008 | Nintendo Wii Console
Pictures too bright
This has happened to me also. You mention that you were changing settings. The symptoms sound like your camera is in a special setting other than "Auto". Examples that would produce such results include Fireworks or Manual. Recommend trying to change your settings one more time:
1. Turn the camera on, and press the FUNC/SET button.
2. Press left or right on your circular dial switch until "Auto" is selected.
3. Press the FUNC/SET button one more time to set the camera to Automatic.
Now take a picture to see if this fixed it.
May 11, 2008 | Canon PowerShot SD600 Digital Camera
Nintendo Wii Handsets
I think that your remots sencer is broken that is what happend to mine when i played 2 player too long gust try to buy new remotes or it is your sencer bar so try one of them
May 05, 2008 | Nintendo Wii Console
It has gone crazy
See if one of the button switches is collapsed, check the "shoulder buttons" also. If any switch is collapsed, it will sense that button as being held down all the time, and may act strangely, including ignoring commands from other inputs or controls. Its possible a bad touch screen could do something similar as well.
Check that all the switches still click and return as they should. If you disassemble unit, you can eliminate the touch screen temporarily by just unplugging the very small ribbon cable to the touch portion of the screen, then see if it still acts up.
Feb 17, 2008 | Nintendo DS Lite Console
Computers & Internet Logo
Top Nintendo Computers & Internet Experts
k24674
Steve P
Steve P
Larry Ng
Larry Ng
Are you a Nintendo Computer and Internet Expert? Answer questions, earn points and help others
