TCL 55" Roku Ready Tv 55fs4690 Logo
Emily Medlin Posted on Jan 01, 2019
I have a tcl 55s405tbaa That turns on and screen Stays black but has sound What part am i needing to fix this.
TCL Roku Television. I need help diagnose a problem please.
I'd start by testing the 12 volt rail at the timing board, see if it drops as the set goes to a black screen, if so, unhook the panel ribbon cables, if the voltage stays your panel is bad and the set isn't repairable, if it still drops off replace the tcon board
TCL tv black screen with sound
Led strips need to be repaired or replaced ,
https://www.youtube.com/watch?v=KaKi5aC9fUQ
1helpful
2answers
My TCL TV is black screen
That is usually a sign that the power supply or the LED's in the display are failing. You may be able to order new power supply or parts for it from shopjimmy.com
TCL TV model 55S405TBAA - when I turn on the TV the backlight will turn on & the sound will come on as well but the video/display will not. I suspect it is a T-Con board issue. What are your thoughts?
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview.]..
Wont turn on
Do you have or get sound or is it total off?
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
john h
ADMIN Andrew
ADMIN Andrew
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
