Watches Logo
C
Carol Schamehorn Posted on Dec 31, 2018
Do I need to set my step strid on my new bfit watch or does it set itself.
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
Please help me setting alarm on my CA-53W watch
To get a copy of your manual go to the following website:
http://jayharrison.blogspot.com/2009/10/casio-ca-53w-watch-and-manual.html
Just below the picture of your watch you will see the following link:
http://www.audiolightproductions.com/manuals/Casio%20CA-53W%20watch%20manual.pdf
Right click on the link and choose "Save Link As.." from your menu. Make sure you save the file in a place that will be easy for you to access it and read it. The file is in the pdf format. If you don't already have the Adobe Free Reader you can download it from this website:
http://get.adobe.com/reader/
Just click on the orange box that has the word DOWNLOAD in it. If you save the file to your Desktop all you have to do is double-click the icon that it creates and the reader will install itself. You can then double-click the file for your manual and it will automatically load the reader and display itself in the reader.
On the first page of the document is a description of how to set the Alarm on your watch which you do so by the following steps:
1) Press the "C" button (the upper one on the right hand side of the watch) twice to get to Alarm mode.
2) Press the "B" button (lower one on the right hand side of the watch) to set the new alarm time.
3) Press the "PM" key to change between AM & PM.
4) Use the "C" key to move from position to position of the display (from 10 HOUR to HOUR to 10 MINUTE to MINUTE).
5) Once you have set the Alarm press the "B" button again to go back to the regular time display. When you are in the Alarm setting mode pressing your "X" key on the keypad will turn the Alarm indicator On and Off. There is a graphic on the screen that looks like a bell. When you can see it the Alarm is on.
The above information should allow you to resolve your issue. However, if you need further assistance, please do not hesitate to post further questions. Thank you for allow us to assist you in resolving your issue.
How to set time
To set a digital watch you must have two buttons.
There must be a "mode" button which steps through the setting screens and a "set" button which adjusts the current setting screen.
Keep looking to find the second button.
As a last resort you should speak to Keneth Cole (set their web site for contact details) and ask them to help you.
1helpful
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
hi
please follow the steps to change the battery
  1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
  2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
  3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
  4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
  5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
thank you....
How do I set the time for nike imara fit WR0076-002 wrist watch?
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Activate T Buton gose to Alarm function.
As with many watch manufacture houses novadays watch technology differs from house to house. Tissot is no difference as T-series watches was developed by Tissot itself.
You have to follow the steps one by one as instructed in your watch manual. Probably you will need reset your watch completely, depending what actions you've allready done.
In case if you lost your watch manual, go to www.tissot.ch and find out everything you need.
Regards
Arthur
4helpful
3answers
I dont know how to set the time
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
9helpful
3answers
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
