GE Side by side GSS25KGTAWW, 15 year old. Set Freezer at 0. In a day or two, freezer is either -6 or -9. Want freezer to stay at 0. Replaced DC Evap Motor in Freezer 3 months ago. How can I keep the freezer to stay at 0? Is the thermostat on the board out or something else. When I reset the temp on control board back to 0, it goes back to zero in time, the DC Motor Evap (WR60X10074) should be WR60X10307, has power surging sounds in freezer. GE wont tell me if different part number purchased from local Appliance Shop could be causing power surges in Evap Motor. Like a motor running high, low, high, low, etc.
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
SOURCE: Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
behind or inside the digital display casing-mike
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
