Http://www.fixya.com/tags/hdtv_antenna/browse/hitachi
https://manualsbrain.com/en/manuals/993851/
SOURCE: hitachi 46f500
This TV set I have seen in the past to have leaky CRT's This is where the cooling fluid that is located between the main lens and the CRT face leaks out onto the printed circuit board. You should have this set checked out ASAP or you will be doomed. If you let the cooling fluid stay on the printed circuit board too long, it will corrode the connections and then you will have to buy a new board, and that would really be an expensive repair. If it is not the fluid issue when you do have the set fixed, ask the tech to install a shield that Hitachi recommends to be installed inside the set, so that in the future, the tubes do become leaky, the fluid will run off to the side and not damage the electronics. If it is not a fluid issue you most likely have a bad flyback or the high voltage distribution block is bad. Good Luck, and let us know how you made out.
SOURCE: Hitachi HDTV Model 46F500
replace convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: Hitachi 46F500 will not recognize a Playstation 3
It is my understanding that the 46F500 HD Ready only goes to 1080i and for Blu Ray you need 1080p. There are no ports for this format.
SOURCE: Hitachi 46F500 TV has red and blurry picture..
If this problem has been gradually getting worse, it is most likely to your picture tubes getting weak, and it is time to replace the set I'm afraid.
If the red is smearing off to the side of reddish objects in the picture it is most definately the tubes.
