SOURCE: canon i350 printer waste ink tray full.
according to cannon the Waste ink ABORBER not tank is getting full. To clear this error press resume and print button. But this will only fix your problem if at all for a short time as this is not considered user replaceable part. You can contact canon on line at http://consumer.usa.canon.com Good luck
SOURCE: can't print when there's only black ink
Here's a trick that worked for me - there are two tiny prisms on the back of each ink cartridge, to refelct light to a sensor indicating whether there is or is not ink in the cartridge. Simply put a small piece of masking tape over the non-mirrored prism, i.e. right next to the mirrored prisms, to make the printer think the cartridge is full of ink. Put the small pieces of tape on each of the three empty color cartridges, being careful not to cover up the mirrored pieces, as light relected from these indicates that there is a cartridge in the slot. The printer will run as if it has full black and color cartridges, but set your defaults to only print black.
SOURCE: CLP-500N Paper Tray error
It wants you to put paper in the multi-purpose or pull down tray 1 assembly.
SOURCE: HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue.
Step one: Reset the product
Step two: Check the condition of the paper and reload it
Step three: Choose the photo tray in the print driver settings
Step four: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
