Televison & Video Logo
K
Keith pillay Posted on Dec 31, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to turn off auto standby on my Hisense JJOA6200 please?
  • Keith pillay
    Keith pillay Jan 02, 2019
    I found it in settings thank you.
Stephen Miller
Level 3:
  • Hisense Master 1,645 Answers
  • Posted on Dec 31, 2018
Stephen Miller
Hisense Master
Level 3:
Answers
1645
Questions
0
Helped
864903
Points
9471
HDD AUDIO PLAYERHAP-Z1ES
  1. Select [Settings] - [System Settings].
  2. Select [Auto Standby].
  3. Select [Off] to disable the Auto Standby function; or [00:20] (factory default setting), [01:00], or [02:00] to specify the period of time before the function is activated.
1helpful
2answers
My Hisense tv model75h6570g has sound and a black screen there is no trace of a picture with a flashlight and the standby light flashes around 20 times before shutting off
Hisense only has 10 blink codes, on most brands they're helpful but not as much on Hisense, in 9 out of 10 sets it turns out being backlights, we've had sets before in our shop where an image wasn't visible, but it still turned out being bad lamp strips. Power boards are a bit different on Hisense sets as loss of backlights can put the set in sleep mode leaving only the standby voltage. Best way to troubleshoot the set would be with a backlight tester
I have a 58" Hisense tv that refuses to turn on
Are you able to get some voltage measurements?
Hi, could someone please help me? I want to use an Alexa plug to turn on my hisense en3g39. But when it turns on it just goes into standby mode and then I have to use the remote to turn it on. How can I...
The Hisense EN3G39 is the remote control for the 55N8700UW, 65N8700UWG, and other TVs. I have never seen an option for removing the standby mode from any TV without a change to the firmware. The TV will always return to the standby mode when power is returned. The type of firmware change that you want will not be available from the TV manufacturer.
The smart plug is great for reducing your power bill when you aren't watching TV. It won't avoid the turn on step.
I wish that I had better news for you.
(I wouldn't recommend trusting a third-party firmware if one exists or was created for your TV. That would void any warranty and could cause problems with the TV.)
1helpful
Hisense b50h5g won't power up standby light turns off screen blank.
1. Open internal fuse
2. Power supply failure
Please check this link: https://www.google.com/search?bih=625&biw=1366&hl=en&ei=muLyX5yZKOraz7sP2_2moAo&q=How+to+fix+Hisense+b50h5g+won%27t+power+up+standby+light+turns+off+screen+blank&oq=How+to+fix+Hisense+b50h5g+won%27t+power+up+standby+light+turns+off+screen+blank&gs_lcp=CgZwc3ktYWIQAzoICAAQyQMQkQI6BQgAEJECOgIIAFCisylY5LspYMrCKWgAcAF4AIABeYgB4AGSAQMwLjKYAQCgAQGgAQKqAQdnd3Mtd2l6wAEB&sclient=psy-ab&ved=0ahUKEwicztGR_oHuAhVq7XMBHdu-CaQQ4dUDCA0&uact=5
Hope this will help.
2helpful
How can i get the channel auto scan on my Hisense 55h6sg tv to find any channels.
If it is asking for zip code you have not told it to scan for over the air or antenna channels when it asks air or cable
We have a hisense model#H32V77C....can"t get it to turn on...
If standby power light is ON, and the set do not come out by standby mode to ON, the fault is with its main board. If standby light too is absent [not light up]; the fault is with its main power regulator board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
HL32V86 Hisense 32' stuck on standby wont turn on it seems screen stay black
Call the HiSense tech dept. You can find the number on line and they will tell you how to fix it or you can try using the remote and go to settings and see if you can fix it that way. Also the manual for this tv should be available online as well.
12helpful
4answers
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
