Could the vent hose be kinked or crushed in a turn or corner? Another thing to check would be that some driers have a separate belt that runs the air circulation blower off from the same motor that turns the drum which has it's own drive belt. If it has a blower belt and it broke, is over stretched, contaminated with oil or slipped off a pulley or if the blower bearings have seized, The drum would still turn and everything would appear to be OK but the high temp thermostat will still shut it down to avoid damage to the unit or a fire. Good luck.
SOURCE: LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
SOURCE: my whirlpool duet gas dryer (model ggw9200lw1) is taking too long
There is a rare chance that the gas supply is clogged. Dealing with gas pipes is dangerous business, don't fool with it unless you are experienced with plumbing. After checking a gas pipe, do a bubble check for leaks with dish soap from a sponge or sprayer. There are small filters and traps placed here and there in the plumbing of some units. They are similar to the ones on a washing machine hose, but smaller.
SOURCE: Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
SOURCE: Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
