SOURCE: magic chef propane oven. recreation vehicle application
you need to check the amp draw on the ignitor.. if it is between 3.5 -5.2 amps your gas valve is bad..if not the ignitor is bad..YES theignitor can glow and still be bad due to lack of amp draw to open the valve..check that and let me know
SOURCE: The main burner won't light the pilot light gets
You have a defective pilot safety valve. Due to the age, the part may no longer be available. If you can find it, have it changed by an authorized gas technician. Also replace the pilot orafice. It should be a .014 orafice.
SOURCE: my propane stove oven pilot light works but main
how do I adjust flame on the top of a new whirlpool stove. It is electric lite,propane stove
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
SOURCE: I have a Hardwick propane stove, 4 burners and
Hello Patrick,
WHen you turn on the oven/broiler does the size of the polot ligh increase in size??
the way it is suppose to work is...thier a small free standing polot light and when ya turn on the oven the size of the pilot is suppose to increase and heat a little bulb that is connected to a wire that is mounted to the pilot burner and when that bulb heats up it will allow the main gas to flow into the oven(not pilot burner).
If the size of the pilot does not increase it could be caused by a clogged pilot burner. the way to determine that is TURN OFF GAS SUPPLY...disconnect gas line from pilot burner and turn on gas to unit, light that tube with it disconnected from pilot burner and turn oven on and see if size of flame drastically increases...if it does turn gas off and remove and replace pilot burner
if flame sizedoes not increase the problem is going to be the thermostat
If the pilot does increase and heats the bulb on the pilot burner the problem will be with the gas valve that,that bulb in the pilot burner accathes to is bad .
now chances of the thersostat still being available is very slim if the pilot burner is clogged and needs replaced they are still available their is 2 of them one has the mounting plate on the left and one is on the right.
here is what they look like
Part number for this one is 1898-021 notice how the mounting tab is on the right
this one is pt# 1898-022 the tab is on the left
That when performing a quick search on google is pretty much all that still available teh thermostat (would need model number) is doubtful to find also a good chance the gas valve is also no longer available
Good luck,
GENE
