SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
SOURCE: i have the HAIER HW-C1260TVE-U
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
SOURCE: My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
