SOURCE: Err LS on Bowflex Treadmill
The machine needs to be re-callibrated. L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
The instruction book doesn't mention calibration. be sure to not callibrate in metrics, however (there's no way to easily tell the difference - you have to ask) or you'll be strolling like a walk in the park at 5 "mph".
Thanks for using FixY - a FixYa rating is appreciated!!
SOURCE: Treadmill adjustment on bowflex 5000tc
There are two hexagonal screws on either side of the front rollers, and four inset hexagonal screws on the back rollers. Turn it on the lowest speed while turning the ones in front, one at a time. You'll see the tread move from one side to the other. Tightening the screws bring the rollers out, pulling the rubber tread taught, and to the left or right, depending on which screw you're turning at the time. The treads should roughly be the same tension, adjusting both inside and outside front screws for each tread. If you have the dual rear rollers, you'd then have to stop the machine after finishing the fronts and tighten the four inset hexagonal screws on each of the rear rollers. No adjustment per se, just tighten them. If you don't, you'll have a sort of clunking, or clicking noise from the imbalance. The single rear roller is a little different, and the adjustment I believe, can be found on this site:
http://nautilus-technics.com/
Good luck.
SOURCE: bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
