Refrigerators Logo
Lucy Hill Posted on Dec 30, 2018
Samsung refrig. Model srs614dw. Motor will not stay on. We have turned off at power then back on to reboot. It works for a liitle while then stops
John Kolakoff
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jan 03, 2019
John Kolakoff
Contributor
Level 1:
New Friend:
Answers
8
Questions
Helped
1951
Points
20
Which motor? Fan or compressor. If it's the compressor its most likely the start relay located on the side of compressor. Do you hear a click right before it quits?
2 Related Answers
Anonymous
  • Posted on May 09, 2008
SOURCE: Samsung Refrigator
how do i fill up the water and ice maker
projdoc
jasbo
  • 2239 Answers
  • Posted on Aug 28, 2009
SOURCE: Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Samsung Tv model QN75Q70TAFXZA stopped working
Count the flash routing, that is the error code and t can point you in the right direction.
Model SRS614DW Problem is as follows, Beeper sounds and Refrigerator Temperature goes up and down the scale, this can happen as much as ten times a minute Fridge temperature remains at the set level . this...
Based on your description, a couple of things you can try:
  • evaporator on the fridge side may need thawing/cleaning;
  • replace the Evaporator Cover Assembly. Samsung has long replaced this original design/component (Jan 2007);
  • check for fan/blower action. They may be frozen, stuck or providing insufficient air flow.
This page might shed additional insights/related information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sub-Zero 650 - Keeps turning itself off. The
HI,
Are you having any fault codes along with this issue? Does the fans and light stop working also? This is unusual, is this the G or O model? I need more information to assist you.
Please let me know.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Our icecube maker has stopped working on our Kitchenaid Model KBLA20EMSS Any suggestions on what the problem might be?
unplug the unit,remove the entire icemaker,then the motor module from the front that operates the harvest and all features,and manually rotate the motor,then re-install the motor on the icemaker and re-install it into the refrige and plug in the refrige,sometimes the ,motor glitches, and after you manually turn them it gets them going again
Fan will not work
mcdevito75 here, Most likely yes, Check the fan by carefully turning it just a liitle by hand, also check for heat at the fan motor base, close to the ceiling. If heat or fan won"t start by hand, replace it.
I have a Kenmore refrig./freezer (top freezer, bottom refrig.) that stays in my garage all year long. After this very cold winter, it has stopped working. The light goes on, but no sound of motor, and...
-Possibly no more Freon.
Try this:
-Turn the control switch all the way to 0. Let it stay for 10 minutes or more then turn it up to number 5 to see it kick the motor or not.
If not then possibly the relay is bad.
But if there is power there then the motor is bad.
Good luck and do not store any food in until it had fixed
Mai
1helpful
3answers
Refrigerator side makes noise, not getting cold
I have same fridge freezer & luckily a extended warranty, engineer has been out on numerous occasions & the motor is getting freezed up, which is why the noise stops when the door is opened. Get rid of it! No solution to the problem...its a faulty appliance & a well known fault with this model or so I have been told. Good luck.
Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
