Go into picture settings and turn off multiple screens
SOURCE: Mitsubishi WD-62628 Projection TV Failure
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
SOURCE: Mitsubishi WD-62827 Problem
Uh Oh! Unless this is something simple like a loose piece inside
the projection chamber shadowing the screen it would have to be the
light engine ($$$) warping due to overheating of its plastic
housing. Check inside the cabinet for loose objects in front of
the lens, then clean all the fan filters, then call your warranty
company.
Hope Ya Fix It!
SOURCE: Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
SOURCE: green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
