Re: Why dose my Belkin blue tooth key board do this, I...
There is a physical issue with the connections inside of your keyboard. The C and the D keys are on the same data line and the C is getting triggered when you press the D key.
On the F-keys at the top row of your laptop's keyboard, you may see a bluetooth symbol, or a "wireless" tower or "waves" type symbol. If you jave this key, hold down the Fn key (lower left corner of the keyboard) and then try different actions with this "wireless" key. Click it and see if a menu comes up or a bluetooth symbol appears or if different lights around the laptop go on and off.
Rest it.To rest locate the reset button in the back of the router.With a tooth pick press gently upon the lights blinks.The satrt anew configuration at http://192.168.1.0 or the router default IP.
If you need more help come back.Post / thumbs / testimonial are welcome!
try an antivirus called net protector . load net protector on your main pc, use a cable to connect your mobile to pc using a compatible software for data transfer.
mobile will get detected in the antivirus software,SCAN YOUR MOBILE may be u are lucky to get blue tooth woking , if the file has come through blue tooth netwoking , pushed by some one when blue tooth was on some time. OTHER WISE do a factory reset and save all data first. if this too fails then the blue tooth hardware/software has to be rectified.
As far as I am aware the mouse you are talking about is NOT blue-tooth but a regular wireless mouse.
It came with a small wireless dongle that plugs into ANY regular usb port and does not need a cable.
Blue tooth does not usually use cables either as it is a wireless format but different to regular wireless
If your mouse is blue-tooth then you should ensure that your laptop or pc also has blue-tooth.
Should it not have blue-tooth then to use the mouse you would need to purchase a usbblue-toothadapter. this is not a cable but is classified as a "dongle" you that's true !
This dongle plugs into any regular blue-tooth port on occasion windows will detect and install the required files but some blue-tooth dongles will come with a cd that you need to install.
hI , to enject cd is look a piece of strong tooth pick insert to a small hole at right corner of cd changer , push and and push tooth pick until the tray comes out.
