SOURCE: kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
SOURCE: Philips Toaster Oven Model HD4464/A
The glass door of an oven toaster usually are inserted in the metal slot just slightly above the hinges, so it can easily slip out and fall. try replace it with tempered glass which can be found in glass supplies
SOURCE: Cuisinart TOB-30 toaster oven
I have the identical problem. Where can I find a replacement foot?
SOURCE: my neff oven's handle has become loose. I cannot
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
SOURCE: need manuel and cook book for hamilton beach toaster oven/convect
I tried to locate the manual with google, but unfortunately had no success. You could ask some specialized manual search engines, like here or here. The services are not for free, but most times worthy - saved my live more than once.
Hi Wayne Caplan, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? A photo would be helpful as to whether the screw is pointing into the door from the outside or out of the door from the inside.
