Question about Polaroid SprintScan Office Equipment & Supplies
I have a problem with a photographic film scanner, a Polaroid Sprintscan 120, which will do a preview scan but freezes when I click scan and crashes Vue Scan.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Try to reinstall the software.
Posted on Feb 28, 2019
5 Suggested Answers
SOURCE:
jackboy
  • 2985 Answers
SOURCE: Previewing or scanning
Is the lamp on? Try uninstalling the software and re install If the lamp remains out check your connections. Try the Visoneer Web site Tech support But I feer is the lamp is out , may mean a new scanner Often the price of lamps and labor preclude repair.
Posted on May 28, 2007
BinaryCode
  • 54 Answers
SOURCE: SCAN STOPS MIDWAY
10.9.3 or 10.3.9?
Since you are running on a Macintosh environment, lets try to use the generic application by macintosh and it usually is embedded already when you install or get a mac computer.
From you desktop, double click mac hd > go to applications folder then look for Image capture, try to scan from there one by one. This will verify if the connectivity is intermittent or if its a bad cable. If the issue persist when you are scanning from that generic app then you may want to try to use a different cable.
Posted on Jun 12, 2008
  • 63 Answers
SOURCE: EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Posted on Aug 21, 2009
n25an
  • 622 Answers
SOURCE: Scanner stopped working in mid scan. Now freezes
reinstall the driver... if that does not work then your scanner is broken and needs to be looked at by a service technician...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 23, 2009
HOW TO SCAN A DOCUMENTS BY USING CANON PIXMA MP145?
Hi
Scan the document using Canon PIXMA its very simple follow the mention below instruction to scan to document, picture & email.
  • Turn on the computer and thescanner.
  • Open the lid of the scanner andplace the photograph face down on the glass scanner bed. Close the scanner lid.
  • Click "Start" on the computer.Click "Programs." Double-click "ArcSoft Photostudio 5.5."
  • Click "File" after Arcsoft programopens. Click "Select Source." Click on the scanner model.
  • Click "File." Click "Acquire." Thescanner will begin to scan the photograph.
  • Click "Select Source." Click"Preview." A preview of the photograph will appear on the screen.
  • Drag the selection box to select theentire photo to scan or a portion of the photo. To crop the picture, click anddrag one corner of the selection box. Adjust the position of the photograph onthe scanner bed if the photo is on an angle.
  • Click "Scan" to begin the finalscan. The scanned photo will open in PhotoStudio editing window.
  • Click "File." Click "Save." A "Save Picture"dialog box will open. Type the name of the picture in the "File Name" field.Click on the arrow located on the "Save as Type" pull-down menu to choose theformat of photograph (JPEG or GIF are the usual formats for internet use).Click "Save." The photograph is now saved on your computer.
Sep 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
SprintScan 4000
paul here i am, what happened, you suddenly ended our session, do you still have the script? we can continue it there if you want. just watch out for my reply.
Jul 30, 2008 | Polaroid SprintScan 4000 Film Scanner
Cant get my computer to recognize my SprintScan 4000
The scanner uses a "twain" driver, try searching for that, it may be one of the files you already downloaded. Just look in the download u got.Also try going to add hardware, select the scanner there and poit it to the downloaded file when uit asks if you have a disk that came with it. Download the drivers to your desktop, rt click and open a folder on the desktop, and drag all of the drivers and the Twain one especially, into the folder.
Feb 06, 2009 | Polaroid SprintScan 4000 Film Scanner
Polaroid SCSI support
Install previous version Insight (5.0)...
Dec 19, 2007 | Nikon Super Coolscan 5000 ED Film Scanner
Scanner incorrectly reads frame position on film
Yes there is
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
32 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
Joaquim Martins
Clive
Clive
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
