If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
hello, Clicking and not switched on because capacitors on pcb power have damage. open and change the capacitors can solved your problem. if any problem after replacing capaditors, let me know . thanks
Internal checking circuits, most likely the high voltage circuit. Take off the rear cover. From where 120 volts AC, leads to a fuse, then to a small high voltage transformer, then a capacitor. Check DC voltage at the capacitor. For me it was 380 volts. This capacitor needed to be replaced. Samsung uses a 100 uf rated at 450 volts. Found some old power supplies and got two capacitors - 150 uf and 220 uf both rated at only 400 volts. Had to connect them in parallel making 370 uf. The voltage check was 391 volts, but my TV is now working.
wont turn on red light just flashes? On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
