SOURCE: Sharper Image Jumbo Universal Remote
i just pirchased a Sharper Image Jumbo universal Remote but i can't find a code for the Pioneer DVR 541H is DVD recorder. Does anyone have this code or a suggestion?
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
SOURCE: the sharper image jumbo touch
The instructions that came with my remote were COMPLETELY incorrect. I made note in pen in my jumbo remote manual. After hours of searching the web and piecing together various blogs, I wrote these easy-to-use instructions:
You can program any jumbo remote button this way (eg. MENU, EXIT, MUTE). Just make sure you press the same button on each remote in steps 4 and 5 (eg. MENU on jumbo remote, MENU or LIST on old remote).
SOURCE: sharper image jumbo sized universal remote control
Hey,
I know how annoying it is to have sth with its instructions. Thus, here you have the manual (I scanned it myself for you :))
http://rapidshare.com/files/202369180/SharperImage-JumboRemoteControl.pdf.html
Regards,
Mario
