SOURCE: Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
SOURCE: Compaq Presario Laptop lost power
the battery charger board, is what I would swap first.
Good luck, keep us posted.
SOURCE: Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
SOURCE: reverse lights fuse blew
hi
check the wire because if the fuse keep blowing there's a wire somewhere on the car that has contact with the frame so everytime you put your car on reverse the 12V wire shortcut on the frame so the fuse blow check all your positive wire and your bulb as well
Good luck
