SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
SOURCE: Konica 7145 F-51-2 Error
Code F51-2 at start-up.
Description:
Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
hope that help!!!
SOURCE: f35 error code
Warm-up was not completed
within a specified period from
the start of warm-up.
• The low fixing temperature
fault detection software is
activated.
The fixing temperature at the
end of warm-up is less than the
specified temperature.
activated.
The fixing lamp does not turn
OFF within the specified period.
SOLUTION
Rewrite the data at
address “P47” in the
25 mode to “0”.
(1) Turn the main switch OFF.
(2) While pressing the numerical keys 2 and 5 of the copy
quantity setting button, turn the main switch ON. This
will enable the 25 Mode. The 25 Mode is used exclusively
to rewrite in memory and, therefore, does not
support normal copy operations.
SOURCE: Konica bizhub C351 copier with a C9401 error code
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
SOURCE: konica minolta bizhub 162 have error C0000(main
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Testimonial: "yes this is right ! i figer out the problem - it was in development unit! tNx"
