SOURCE: Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
SOURCE: Bosch Dishwasher SHX46A latch stuck in down possition.
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
SOURCE: Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
