Televison & Video Logo
T
Timi Kesmarsky Posted on Dec 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have a crackling sound like krrrrrr in one of my Samsung LED TV speakers when I play anything. I mean the sound is not clear. How can I fix it? The model number is UA40D6600WRMXL.
Samsung 3D LED TV Model Number: UA40D6600WRMXL
City View TV & Computer, Inc.
Level 3:
Master:
  • Samsung Master 453 Answers
  • Posted on Feb 08, 2019
Samsung Master
Level 3:
Master:
Answers
453
Questions
Helped
147674
Points
1036
1. Check the cable connection between the TV and the set-top box, or DVD player.
2. try to change a different DVD player or a set-top box.
3. Replace the main board.
You may search on google or EBay to get the main board. We never had a defective speaker on Samsung TVs.
Testimonial: "I have no DVD player or anything attached. I think the speakers are faulty. I can't find the spare part anywhere. I have the part number."
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 12, 2008
SOURCE: RCA D52W26 that won't power on.
Yes that would be the model number. What item are you needing assistance with, as I have so many people I am helping that I need you to indicate the problem unless you respond by the origional post. Let me know what you need help with and I will be able to help you I have alot of experience with RCA/Thomson models
Michial Gueffroy
  • 1140 Answers
  • Posted on May 19, 2009
SOURCE: No sound coming out of the left speaker
It sounds like you have a break in your cord right where it joins the plug. You will either have to replace the plug or buy new headphones.
vinhson65
  • 257 Answers
  • Posted on Aug 14, 2009
SOURCE: my samsung lcd tv.32inches.lost sound
Have you try to play with a DVD or other source beside cable? Did you check the TV speaker is on or in mute mode? Try to get TV back to factory reset.
If does not help, check the TV speakers by plug in an AV source.
Lastly, replace the main board.
Chi Chu
  • 8457 Answers
  • Posted on Sep 02, 2009
SOURCE: Toshiba 42H81 speaker crackle
It could be the board or the speakers itself.
Check see if ur air tv have any crackles?
If not u can rule it out the speakers.
Tries it with diffrent cables,see what happen.
The prob.still there it ur electronic board.
Anonymous
  • Posted on Nov 28, 2009
SOURCE: My JVC TV model number HD-52G786 has no sound
How to replace speakers that crackle on 5year old Samsung Smart LED TV. Flat screen.
try checking audio cables if ok audio settings if ok try external speaker if able
I have a Samsung admire cell phone. That the speaker crackles all the time. How do I fix it.?
Have a blessed day. This is adieh
When the speaker crackles all the time as you make a call or hear when someone calls or when you listen to music is faulty and needs to be replaced .Once you replaced it you will be able to hear the sounds clearly when someone calls you and when you play your song.
Hope it helps.
Thank you for using fixya.
2answers
When I turn my tv on my speakers work for apprx 5 minutes than start crackling very loudly then go out.What could cause this ?
Hi, My samsung dlp 46 tv was making a loud crackling and popping sound from the speakers, I turned OFF all the volume
control on my tv from the menu the srs, the auto tune volume, the internal volume which, is the main one which silences the crackling sound immediately! But, you must have surround sound and play the tv volume through your surround sound and wa laaaa, it WORKS! The tv may eventually stilll go out before or if I decide to have it fixed. It is about 3 years old.
Hi. When switched on the speaker makes a loud constant crackling sound. Nothing will work, no keys, stops, anything. Just a loud crackle!
This usually means that the speaker is blown. Try running through a different setup and see if it fixes the problem. Hope this helps
Oct 01, 2009 • Music
2answers
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
1helpful
Creativr Gigworks S750 Subwoffer intermittent sound
The S750 system is a great sounding one but unfortunatly like many similar systems all the amplifiers and power supplies are housed inside the sub box. This means they suffer badly from heat and vibration problems (they cook themselves or shake themselves apart). I have fixed a few S750 systems in the past but due to their complexity it's not for the faint hearted.
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Crackling Speakers
It sounds to me like an impedance mis-matching problem!!!
But it does seem you have done everything correctly so I cant offer any other suggestions - sorry!!!!
1helpful
My speakers have almost constant crackling noises
Hello, there is no chance that you can fix this problem by replacing speaker wires. Resoldering the output stages as well as area around the microprocesor could be the efficient solution. If you need more info please advice.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
