SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
SOURCE: Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
SOURCE: The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
