Locks & Locksmithing Logo
Craig Wybenga Posted on Dec 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kaba e flex 2000 lock set that the levers have become very loose and sloppy, are there replacement bushing available for this problem?
Chris Walker
Level 3:
Top Expert:
  • Locks & Lock... Master 1,573 Answers
  • Posted on Aug 01, 2019
Chris Walker
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245580
Points
21965
2 Related Answers
Anonymous
  • Posted on Jul 17, 2012
SOURCE: My KitchenAid tilt head lock
In my case the lock was not engaging fully because the internal mechanism was bent too short. I'm not sure if this happened over time or if it is just a manufacturing defect. If your mixer still has some up-and-down play to it when the lock is engaged, then you might have the same problem as me
To fix it, search this site and others for instructions on how to remove the motor cover. I found this video useful: http://www.youtube.com/watch?v=VeCiivPt7hk
With the cover removed you have access to the locking mechanism. In my case, the latch is connected to the locking lever via a bent S-hook. The hook was just slightly too short which kept the latch from engaging completely. If you remove the two screws holding the hook in place and that allows the lock to close completely, then you have the same problem as me. (You'll feel the difference immediately. When fully locked, there is practically no wobble in the mixer head.)
I lengthened the hook by placing it against a flat surface and hammering the bend out a bit.
Anonymous
  • 963 Answers
  • Posted on Aug 24, 2012
SOURCE: kaba lock won't open with code
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
1helpful
Will a new shifter fix a problem where the old shifter will not stay in reverse?
Sounds more like a linkage issue. Try tightening the linkage links, replacing any loose bushings. (The detents, or stopping points, on the shift lever have little do do with the shift lever.)
1helpful
2answers
I have a 1989 300zx manual trans. Will not shift in to reverse what coud be the problem
Sounds like linkage from shift lever to transmission or the bushings on the linkage points. A "sloppy" shift lever with similar bushing problems may be the problem.
1helpful
How do you tighten gear lever on cortina 1600e thanks
Inspect Linkage between shifter and transmission. Determine where the sloppy looseness is. Replace sloppy linkage parts if transmission lever is not loose. Pray you don't need to have shifter leverage (inside transmission) repaired.
Front wheels out of alignment steering is hard to turn
Sounds like you got a Murray, Yardman, etc. Steering system is of very poor quality. Front axle has plastic bushing on spindles they break and don't take much abuse. Spindles bend very easy and so with these conditions steering becomes hard and unpleasant. Front axles are not there strong point. Jack up front of mower and check for loose, sloppy wheel conditions. Go from there. New bushings and parts are available at varies places. Best repair would be to think about a mower with a strong front axle. Cast iron, steel etc, rather than a stamped out thin metal one that will always give you problems. Who doesn't bump trees, curbs, yard ornaments etc.
Aug 15, 2014 • Garden
Hydrostatic transmission control lever has become sloppy. When shifting now grinds.
my mower did the same thing i used it until it broke and replaced it
Shift lever
you have the two pawls jammed.. get under there and click them both into neutral by hand.. then set your linkage to be tight there while shifter is in neutral... if the shifter linkage is old and sloppy it will happen again til you replace the shifter bushings...good luck
Simplex 1000 lever handle when correct combo put in lock combo lock operates fine except unless you let the lever snap back lock dose not reset in locked position, in other words if you slowly let the...
I don't have a direct answer, but here is the contact info you need for customer service:
1-800-849-8324 (option 1)
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Tech Support is probably your best bet!
4helpful
Shifter is very loose, sloppy.
The shifter linkage has a two piece plastic / nylon bushing at either end of the gear shift tube that goes from the gear shift lever to the transmission. As the bushes wear through normal usage the gear shift becomes sloppy. The bushes at the gear shift lever end usually wear out first.
You may have to drop the exhaust pipe to access the underside of the gear lever as there is not a lot of space to work in above the exhaust.
To replace, remove the securing nut and through bolt where the underside of the gear lever U section attaches to the tube. Pull down the tube and the worn bits of the bush will come out. Place the new bushes in either side of the tube and put tube end back between the U section. Replace the through bolt and nut. If still a little sloppy, you may have to do the transmission end bushes as well.
Unican combo lock handles are loose
If the handle has been forced their is a part inside that is broken and it appears as if the handle is loose. I have priced the replacement parts and they were over 75% of  what I could purchase the whole thing for ,so I elected to purchase new and go with the direct replacment model L1000 (Lever) to make it ADA compliant at the same time.
8helpful
4answers
Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
