Question about Korg Music
Buttons not working on transport and global mode on KORG OASYS
2 Suggested Answers
SOURCE:
  • 3156 Answers
SOURCE: My Korg TR 61 some buttons doesnt work.
It's more likely to be a cleanning issue. Really, it's almost as easy to replace the switches as to clean them. Parts are available on ebay for very little money.
Posted on Sep 22, 2015
Testimonial: "Thanks,rhodesworks,i will check out!"
When i star or on my korg x5d the display are just like cherismas light it does not finishe inistalation and logo of korg x5d then it will be empity lignht scren
How to Initialize (reset), and preload on the Korg X5/X5D/DR Initialization: Hold Page + and Page - while turning it on.
Preload: Global Screen 5A, then select "OK".
ROM Check: Hold Edit and Global/Multi while turning it on.
Apr 17, 2016 | Korg Music
When i did the INTIALIZATION in korg x5, the PROG,COMBI,GLOBAL & MULTI is not stopping in blinking. How will i proceed to PRELOAD??? Pls help me. Thank you. Add a Comment:
If the answers I have provided you with already don 't work for you, or don't apply to your specific problem, you need to contact Korg customer service for an answer. Here is their link-
http://www.korg.com/us/support/contact
Mar 15, 2016 | Korg Music
Sep 21, 2015 | Korg Music
How can we off the touch of korg X5D keyboard?
If you mean is to OFF the key touch,this is the steps :
  • Press GLOBAL.
  • Press PAGE+ . Find menu VELOCITY CURVE. To select parameter,use left/right arrow buttons(move cursor).
  • Set the value to 0,by press up/YES or down/NO buttons, or use VALUE slider.
Jul 05, 2015 | Korg Music
Korg i3 keyboard no sound out
Step 1:
Check the setting of LOCAL CONTROL in GLOBAL mode.
Go to GLOBAL mode page 1 (Figure 1-2):korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-0.jpg
korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-1.jpg Move the cursor from the MASTER TUNE to LOCAL CONTROL. Setting LocalControl should be in the ON position.
When the setting is OFF,set it to ON (use dial TEMPO / VALUE or DOWN / UP button).
Go back to ARR or PROG mode,and play the key to check audio.
Step 2:
If in step 1, the sound still does not exist, then it is a hardware problems, and the possibilities are :
Figure 3, the section in red shading is a block may be damaged.korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-3.jpg
Figure 4 is a scheme. korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-6.jpgParts that might be damaged in case of no-audio are:
IC 2,4,5 (4570), IC9 (78L05), IC6 (PCM69AU), IC 3 (5216).
Check also the transistors Q1-Q7 (This is the MUTE transistor, and this is most often the cause in case of no-audio).
If you can not fix it by yourself, then leave it to the experts.
Sep 06, 2014 | Korg Music
Factory reset on korg x 50
FACTORY RESET:
  1. Press the [GLOBAL] button to enter Global mode.
  2. Press the [EXIT] button.
  3. Press the [UTILITY] button
  4. Select "Load Preload Data," by using the ClickPoint [?] button, and press the [CENTER].
  5. Choose "Kind," (All)
  6. Press the [MENU/OK] button.
  7. When a dialog box will ask you, press the [MENU/OK] button
May 01, 2014 | Korg X50 X-50 Keyboard
KOrg X5D is out of tune
Did you try to get to Global mode, and then check if the tune is 440 hz?
Check the Global Settings. The tuning might either be altered or the key transposed..
May 05, 2013 | Korg X5d
My korg x5d doensn't show bank A anymore. Instead of A01 - pipedreams lcd screen shows blinking A01 and InitProg01???
You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
Feb 26, 2013 | Korg X5d
How to reset the korg m50
PLEASE HELP ME... this appeared in my KORG M50.. says. LOADING OS FAILED..... Is ther a solution to this...
Jan 23, 2012 | Korg M50 88 Note Workstation
Music Logo
57 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
