SOURCE: Sanyo DS31520 TV
31" Sanyo tv I turn it on, 2 seconds later it shuts off. Can this be reprogramed?
SOURCE: Sanyo camera shuts down and won't power up
Very likely your AC adaptor is broken and not providing power to the device.
I have a Sanyo VAR-G9 that failed.
Take your AC adaptor to Radio Shack, and they may be able to give you a "universal" replacement.
I am using a Radio Shack P/N 273-1696 adaptor and my Xacti HD2000 is now working again.
SOURCE: factory reset
in thid you have reset you tv with help of tv remote . this syestem is used because while seeing at night some oerson sleeps. so he set timer after which the tv gets turned off. to solve this you have to go in menu and you to search for a tinner or sleep option it can be directly on your tvv remote
SOURCE: 32 ''Sanyo DP32648 TV has horizontal line running across screen
If you do not have any bad capacitors Problem will be the Display Panel
Call Encompass Parts Distribution or visit their website and type in your Model number 1-800-638-3328
SOURCE: How do I reset my
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
